Polyvinylpyrrolidone, also known as PVP, is a crucial fine chemical derived from acetylene. It has a molecular formula of (C6H9NO)n and is characterized by being tasteless, odorless, and low in toxicity. PVP exhibits excellent physiological inertia and biocompatibility, causing no irritation to the skin or eyes. Commercially, PVP is available as a solid white or milky white powder.
PVP comes in various molecular weights due to differences in the n number, representing the degree of polymerization. These different molecular weight ranges are typically expressed by K-values, such as K-12, K-15, K-17, K-30, K-60, and K-90.
PVP is known for its universal solubility in both hydrophobic and extremely hydrophilic solvents. While it dissolves easily in polar solvents, it can be challenging to dissolve in weakly polar or nonpolar solvents. However, the addition of a co-solvent can enhance its solubility in these less polar solvents. The unique molecular structure of PVP allows it to dissolve in water and various organic solvents, making it a versatile compound.
The molecular structure of PVP gives it surface-active properties, allowing it to adjust the rheological properties of dispersions or solutions. Its ability to form hydrogen bonds with inorganic and organic compounds makes it an excellent coagulant and surfactant, widely used in various applications.
PVP's strong polar amide group enables it to form complexes with many substances, enhancing their stability and solubility. These complexes have found applications in medicine and pharmaceuticals, improving the solubility of otherwise poorly soluble drugs.
PVP exhibits high stability under normal conditions, with minimal changes even after exposure to heat or certain chemical initiators. Its stability makes it a reliable compound for various applications.
Extensive studies have shown that PVP is biocompatible and safe for use, with low toxicity levels and no harmful effects on the human body. Its physiological inertness and safety profile make it a preferred choice in many industries.
