Product Name: Diethyl azodicarboxylate
Synonyms: Diazenedicarboxylic acid, diethyl ester; Diethoxycarbonyldiazene; Diethyl (E)-1,2-diazenedicarboxylate; Diethyl diazodicarboxylate; dlethylazodicarboxylate; Ethyl azodicarboxylate; Formic acid, azodi-, diethyl ester; DIETHYL AZODIFORMATE
CAS: 1972-28-7
MF: C6H10N2O4
MW: 174.15
EINECS: 217-821-7
Structure
Melting point: 6°C
Boiling point: 106°C (13 mmHg)
Density: 1.106
Refractive index: n20/D 1.47
Fp: 85°C
Storage temp.: 2-8°C
Solubility: Miscible with dichloromethane, diethyl ether, and toluene.
Sensitive: Air Sensitive
Diethyl azodicarboxylate is a versatile compound used as a liquid blowing agent and pharmaceutical intermediate. It is also employed as a vinyl resin liquid foaming agent, contributing to the production of light-colored vinyl foamed plastics with a uniform microporous structure. Additionally, it finds applications as a medicine intermediate and organic synthetic reagent.
To purify DEAD, dissolve it in toluene and wash it with 10% NaHCO3 until neutral. Subsequently, wash with H2O (2x), dry over Na2SO4, filter, and evaporate the toluene. Distill the remaining substance through a short Vigreux column at a high vacuum. The main portion boils at 107-111o/15mm. Due to its explosive nature, it is crucial to use an oil bath for heating and perform all operations behind a sufficient shield.
