In the world of skin care, retinol and adapalene are the ingredients that have attracted much attention and are known for their unique effects. Choosing a product suitable for your skin can help improve your skin state and glow for natural glory.
background:
Aimedol -type is a collection of vitamin A and its analogs , which is biochemical and molecular biological nouns announced in 2008. Both retinol and adapalenes are type of retinol -like. Adapalene is a kind of topical vision, which is approved by FDA to treat ordinary acne. Vitanol is a vitamin A derivative. It is usually described as an agent. The descendants are more specific to the affinity of cloakic acid receptors (RAR).
adapalene (adapalene), chemical name: 6- [3- (1-diamond) -4-methoxy-phenyl] 萘 -2-methic acid, molecular formula: C28H28O3. adapalene is the preferred drug for light, moderate acne acne and inflammatory acne. Adapalene (adapalene) is the third -generation vitamin A -type anti - drug. , Soluble angle and acne and anti -inflammatory effects, have good therapeutic effects on non -inflammatory damage and inflammatory damage of acne . It is generally believed that ADAPALENE has a good tolerance compared to other vitamins A acidic drugs. Local irritation and good safety.
( 2) retina
retinol is an organic compound. The chemical formula is C20H30O, which is a form of vitamin A. It is usually called vitamin A1. This compound belongs to a binary alcohol, which can be converted into other forms of vitamin A, and uses its ester derivatives as the storage form of vitamin in the animal. Retinol is widely used in the field of beauty and is often used to improve wrinkles, fine lines, dryness and skin texture.
1. visuolhin vs adapalene
1.1 Source
1.2 action mechanism
The viscerosol and adapalene are combined with the visually visually visual acid in the skin. This combination will trigger a series of cell incidents, thereby increasing skin cell renewal, reducing inflammation and collagen production. However, they are targeted at specific RAR and their effectiveness.
( 1) Adapalene: This synthetic retinol is selectively combined with RARβ and RARγ. It is more effective than retinol, making it the first choice for treating severe acne.
( 2) Retoslene: retinol is a natural form of vitamin A. Before combining with RAR, it will be converted into oscillatic acid in the skin. This conversion process may be not as effective as adapalene, so its effectiveness is usually low.
1.3 for acne
( 1) Adapalene: Because of its effectiveness and selective targeting RAR who participates in the pathogenic mechanism of acne, Adapalene is more effective in treating acne than retinol. It is the only over -the -counter retinol approved by the FDA to treat acne.
( 2) Retosol: Although the retinol can be used to treat acne, its effect is usually gentle than Adapalene. It has not been approved by the FDA for this purpose.
1.4 adapalene VS retinol for wrinkle removal
Retinol is often recommended to treat wrinkles. It penetrates deep into the skin and stimulates the production of collagen more effectively, thereby reducing fine lines and improving skin texture. Although Adapalene shows some prospects in the treatment of skin aging, it is mainly used for acne. Vitaminic acid has been approved FDA approved to treat skin aging, but adapalene and retinol have not yet been approved.
Comparison studies conducted by Bagatin and others showed that the clinical effect of 0.3% Adapalene gel was comparable to 0.05% vitamin pyromicine cream. Therefore, 0.3%Adapalene gel is recommended as effective treatment for mild or moderate light aging patients. Pinto et al. Pinto and others developed a NLCS preparation containing 0.1% Adapalene with a fine lactation method, and used a balanced dialysis method for in vitro release experiments. The new preparations show good performance from a technical perspective, but it also needs to be further studied to reveal the potential of the preparation for anti -aging therapy.
1.5 Use age
( 1) Adapalene: Adapalene is suitable for people 12 and over.
( 2) Retosyle: There is no specific age limit using retinol with retinol, but it is usually recommended to use adults to prevent or treat signs of aging.
2. Can I use adapalene and retinol together
vitamin A (such as adapalene and retinol) is usually not recommended to use at the same time. Although the two can be combined in theory, it is not actually recommended, because both are externally used to see yellow alcohol, which is not necessary to reuse. Therefore, it is best to choose one of them according to their own needs.
3. Suggestions
Whether it is retinol or adapalene, they each have unique advantages and applicable scenarios. When choosing a product suitable for your skin, it is recommended that you consult a professional doctor or dermatologist to ensure the best choice based on your specific skin condition. Professional guidance can help you develop a safe and effective skin care solution and make you better realize the ideal skin.
refer to:
[1] https://baike.baidu.com/item/%E7%B1%BBB%E8%A7%86%E9%BBBB%E9%86%87
[2] https://baike.baidu.com/item/%E8%A7%86%E9%BBBBoss
[3] https://zh.wikipedia.org/wiki/%E8%A7%86%E9%BB%84%E9%86%87
[4] https://en.wikipedia.org/wiki/adapalene
[5] https://www.ncbi.nlm.nih.gov/books/nbk482509/
[6] https://link.springer.com/article/10.1007/s12325-022319-77
[7] Guo Chenchen. The nano carrier of the acid sensitive polymer is used for research by adapalene. [D]. Tianjin University, 2014.
